Can I use component path leaf/root pointers in Excel VBA?
Running up against what might be a bug in the VB API when using Excel.
This is simply trying to get the PTC-provided example listSubAssemblyComponent to function in Excel VBA rather than its original VB. I intended to make this the basis of code to extract the model tree into an Excel spreadsheet for internal engineering management purposes - old way we do this is to save the model tree from Creo, and import it into a spreadsheet via VBA macros, but I want a more streamlined way to do it. (This ain't necessarily it, and I'm open to better alternatives.)
It appears to allocate something to currentPath (typing ?currentPath is Nothing in the immediate window returns false). But it hangs up every time on the line with currentPath.Leaf, returning the message:
Run-time error '-2147352567 (80020009)':
pfcExceptions::XToolkitGeneral Error
I don't see any useful explanation of this error. I've fiddled around with everything I can think up on how to get around it, but I'm starting to believe it's a bug or else something available in VB but not VBA for some reason.
Ideas? What am I missing?
Sub listSubAssemblyComponent(ByVal currentLevel As Cintseq)
'Function  :  listEachLeafComponent
'Purpose    :  This function This method is used to recursively visit
'              all levels of the assembly structure.
    Dim currentComponent As IpfcSolid
    Dim currentPath As IpfcComponentPath
    Dim level As Integer
    Dim subComponents As IpfcFeatures
    Dim i, id As Integer
    Dim componentFeat As IpfcFeature
    level = currentLevel.Count
    Set currentPath = Nothing
    Dim dummyModel As IpfcModel
    'Special case, level is 0 for the top level assembly.
    If (level > 0) Then
        Set muhAssy1 = New CMpfcAssembly ' *** original PTC VB code had this step inline with currentPath, but that won't work with Excel VBA
        Set currentPath = muhAssy1.CreateComponentPath(asm, currentLevel) ' *** was originally = (New CMpfcAssembly).CreateComponentPath(asm, currentLevel)
        Set currentComponent = currentPath.Leaf ' *** this is where the failure occurs ***
    Else
        Set currentComponent = asm
    End If
    Set dummyModel = currentComponent ' *** as above, added this step because in Excel VBA, currentComponent's type (IpfcSolid) doesn't allow the .Type property)
    If (dummyModel.Type = EpfcModelType.EpfcMDL_PART) And (level > 0) Then
    ' *** code below is original PTC example, just changed from VB to VBA syntax in Excel ***
        pathArray.Add currentPath
    Else
        'Find all component features in the current component object.
        'Visit each (adjusting the component id paths accordingly).
        Set subComponents = currentComponent.ListFeaturesByType(True, EpfcFeatureType.EpfcFEATTYPE_COMPONENT)
        For i = 0 To subComponents.Count - 1
            Set componentFeat = subComponents.item(i)
            id = componentFeat.Number
            currentLevel.Set level, id
            listSubAssemblyComponent currentLevel
        Next
    End If
    'Clean up current level of component ids before returning up one level.
    If Not level = 0 Then
        currentLevel.Remove level - 1, level
    End If
    Return
End Sub
'This function is used to recursively visits all levels of the assembly structure.
Private Function listSubAsmComponents(ByVal currentLevel As Cintseq)
    Dim currentComponentModel As IpfcModel
    Dim componentFeat As IpfcModelItem
    Dim Compids As New Cintseq
    Dim CMpfcAssembly_ As New CMpfcAssembly
    Dim i, id, level As Integer
        PrintInfo (Str(level))
            If level > 0 Then
                Set currentPath = CMpfcAssembly_.CreateComponentPath(useAsm, currentLevel)
                Set currentComponentModel = currentPath.Leaf
                Else
                    Set currentComponent = useAsm
                    Set currentComponentModel = useAsm
            End If
            If (currentComponentModel.Type = EpfcMDL_PART) And (level > 0) Then
                Else
                ' //** REMOVE below lines if Not interested in collecting Assemblies
                If Not currentPath Is Nothing Then
                End If
                ' //** REMOVE above lines if Not interested in collecting Assemblies
                    'Find all component features in the current component object. Visit each (adjusting the component id paths accordingly).
                    Set subComponents = currentComponent.ListFeaturesByType(False, EpfcFeatureType.EpfcFEATTYPE_COMPONENT)
                        For i = 0 To (subComponents.Count - 1)
                            If (subComponents.Item(i).Status = EpfcFeatureStatus.EpfcFEAT_ACTIVE) Then 'Collect only Active Components
                                Set componentFeat = subComponents.Item(i)
                                id = componentFeat.id
                                Call listSubAsmComponents(currentLevel)  '#### RECURSION
                            End If
                        Next i
            End If
            End If
End Function
