Can rows in Family Table be re-ordered
I have a family table (FT) for an assembly. I had to re-name the instances in Intralink. When I went back into the FT, the instances were not in the same order as they were before the re-name.
In the FT editor, there is a choice for Tools > Sort > Ascending (Decending). When I pick this, it only re-orders the column for Instance Name. How can I get my entire FT to re-order so I do not lose the structure of the FT for all of the instances. I tried to do this in Excel as well, and I could not get it to sort.
Dennis
Dale_Rosema
No they cannot.
Here is a product suggestion:
http://communities.ptc.com/ideas/2043
You'll have to cut and paste the link.
Thanks, Dale
Dale,
Thanks for the response. It is deceiving that they have the choice there, but it does not work the way it should.
Dennis
Dale_Rosema
In the system I am using, the columns can only be swapped two at a time, so if you can sort them more than than, that is good.
(Sorry I am playing with the link to see if I can get it to link correctly)
Dennis,
For row swaps, it is a GIANT pain, but I think I just found a way around this. You should be able to remane and sort by the instance name.
In front of your instance type "a1"-"a-9", then "aa1"-"aa9" and so on and so forth for every instance, and you can sort by this. I just re-ordered 22 objects and now am adding comment rows so HOPEFULLY next person is smart enough to add an instance in a logical way by the way I have it sorted.
