Oct 23, 2015 6:04 PM UTC
Can you make annotations parallel to, normal to, or coincident with the surface to which they apply in a drawing?
I have enabled the allow_3d_dimensions within the dtl file, but am still unable to make notes and/or tolerances show up in any configuration other than flat to screen. Does anyone know if these can be shown in the same manner as "3D Dimensions"?
Dale_Rosema
Oct 26, 2015 7:19 PM UTC
See if this thread helps:
Re: Editiable annotations/dimensions
Thanks, Dale
bboman1-VisitorAuthor
Oct 27, 2015 1:33 PM UTC
I appreciate you sharing that thread, but I am trying to figure out how to transfer the orientation of my annotation elements onto a drawing graphic sheet. No matter what plane or surface I reference when placing the annotation element in the model, the annotation element will not show up in that configuration on a drawing. Essentially, I would like to create drawing views like the one seen below.
Oct 27, 2015 2:44 PM UTC
That looks like Model-Based Design, governed by the standard ASME Y14.41, where drawings are governed by ASME Y14.5 (dimensioning+tolerancing), Y14.3 (views), etc., and call out different behaviors, specifically not having text on a plane angled relative to the paper.  We might support having an image being placed in a drawing which is a MBD combination state presentation from 3D, but having it 'as a view' would be contrary to 2D detailing standards, so seems less likely.
