Oct 12, 2016 9:23 AM UTC
Canbus_Cable_4Cond.rar
Hello Dear All Friends.
. I want to use PTC Creo Cabling and PTC Schematic to design firefighting trucks’ 3d harness and electricak diagram. I can create single cable and I can write csv file but I didn’t create multilevel cable. You can see the attached files.
For Example:
I need a canbus cable. The cable has to two pair, pair_1(red and black wires), pair_2(white and blue wires)
Step-1:
I created template wire in fibers
Step-2:
I selected group from type after that I created new folder than I created new block in the folder.
Click to new group and define dataset (Canbus_Pairs) next step
I created new shape in new group then I drew pair cable to use a template wire.
And
I created the same way in pair_2
I can use cable (pair1 and pair2) in design. So, When I connected first wire to port and other is automatically to other port. It is normal.
But
I created same step in multilevel cable.
But I didn’t use multilevel cable in design.
Error shown on the screen?
Can you tell step by step to create multi level cable to me?
hcihat1-VisitorAuthor
Oct 13, 2016 10:28 AM UTC
I solved the problem.
