7-Bedrock
"Cannot have more than one outer loop" in ECAD-MCAD Collaboration for IDX
I am using Creo Parametric Release 9.0 and Datecode9.0.8.0
When I am transition my old IDF board to an IDX file, it is giving me an error with my ECAD areas. When I try to edit the sketch of my ECAD area and hit "OK", it gives me the error "Cannot have more than one outer loop". I have several circular areas within my sketch that all should be route keep outs.
Is it telling me that I have to make individual features for each of my many zones?
That would be a very inconvenient way to model several of the same type of zone. Each zone is slightly different and can't be created using patterns. Is there a workaround to this?
Here are the errors that I faced
tbraxton
tbraxtonAnswer
Starting with Creo 12.4.0.0 the functionality you are seeking became available. See release notes here: https://support.ptc.com/help/creo/creo_pma/r12/usascii/index.html#page/whats_new_pma/ecad_sketch_regions_support_for_ecad_areas.html
In Creo 9 you are probably stuck with using a separate sketch for each ECAD area definition (one closed loop per sketch). It is likely possible to pattern or generate sketches for the circles; post the sketch of the circles you want to use to define the keep outs (just save the section from within sketcher). You must zip the sketch before posting.
tbraxton
tbraxton22-Sapphire IIAnswer
