Cannot hide welding symbols away when printing main view in a .asm file with weldings
I am using Creo Parametric 7.0 7.0.3.0
When I print the main wiev of a welded assembly in creo parametric, it prints all the welding symbols even if they are hidden. How do I print just the assembly without the symbols?
It was not drawing specific, but I manage to solve the issue by manually selecting each welding annotation in the assembly with a right mouse button click and then selecting the [ - ] button on the drop-down window to remove it from the model. Repeating the task for every weld feature until the model was clear allowed to print just the geometry without welding annotations.
Mahesh_Sharma
22-Sapphire I
Hi @GV_9230764,
Is it specific to a drawing? You can try creating a new drawing for same data to check if it is drawing specific. If in case it turns specific to drawing, add drawing option update_drawing as all, update drawing and test issue.
Thanks.
Mahesh_Sharma
22-Sapphire I
HI @GV_9230764
Did you manage to test printing with suggestion in last reply?
GV_92307641-VisitorAuthorAnswer
Mahesh_Sharma
22-Sapphire I
Thanks @GV_9230764
