May 23, 2022 4:01 PM UTC
Cant acess IFX
I am using Creo Parametric Release 4.0 and DatecodeM140
the intelligent fastener extension does not appear in the "tools" window of Creo. I was wondering how I install or use it.
    May 23, 2022 7:42 PM UTC
    Maybe you have the option  intelligent_fastener_enabled set to no. in config.pro file or either in config.sup.
    If so, then set it to yes value
    May 23, 2022 9:54 PM UTC
    The IFX license is an option and costs extra. Creo 3+ comes with a basic IFX license, but you cannot modify anything with files supplied.
    May 24, 2022 6:59 AM UTC
    Not necessarily. In latest Creo Design packages full IFX is bundled with a base Creo Design Essentials package (along with some other extensions like AFX or Cabling & Piping). It's an extra extension only if you have some older packages and not upgraded them to Design Essentials or higher.
    May 24, 2022 8:53 AM UTC
    Dear customer,
    As previously said, you need a specific license to access the IDX module from Creo Parametric.
    Please can you check if such license is available in your Creo 4.0 session :
    > File  > Help > System Information > Configured Option Modules , then check if  IntelligentFastnerExtension is listed.
    Waiting your information
    Cheers
    May 24, 2022 8:54 AM UTC
    Sorry for the typo , I mean IFX
    May 31, 2022 12:54 PM UTC
    To check the installation, browse to Common Files folder and confirm the ifx folder is present.
    Another way is to run set-up again.
