3-Newcomer
Carrusel
I need help with the movement of a carousel. Does anyone have any idea how to make different parts move up and down while the carousel is rotating?
Michael_Bourque
You would assemble the parts with Mechanism connections instead of fixed assembly constraints. Use a Pin connection for the rotating carousel and Slider connections for the vertical motion. Then, in Mechanism Design, add servo motors to drive the rotation and the up/down movement. If you want a realistic carousel mechanism, use a cam-follower connection so the vertical motion is caused by the rotation.
Michael Bourque
MikeBennett
Mechanism constraints are a great template for this but are not required for enabling motion.  A Pin connection can also be created using a plane-plane mate and an axis alignment normal to the planes - just ensure that Allow Assumptions is unchecked, otherwise Creo will assume a 3rd constraint to prevent the unconstrained rotation!
