Center of Gravity of part in a assembly reference coordinate system
Hello
I am faily new to creo
i am using creo 7
I have an assembly and have defined a custom coordinate system origin in the assembly file
i am trying to get the center of gravity of a part in the assembly with respect to my "assembly" custom CS
What i am seeing is:
1) i can only open the part and get the CS of the part with respect to a CS "inside" the part file.
or
2) i can get the CG of the whole assembly with respect to a custom CS.
both options are not what i need
i need the CG of a part in an assembly with respect to a custom "assembly" CS
any help would be greatly appreciated.
thanks
you can:
  • open assembly
  • in Model Tree select part, press RMB and use Activate command ... now you can add new CSYS into part
  • add new CSYS referencing assembly CSYS
  • press CTRL+A ... this command activates assembly
  • open part
  • compute COG using new CSYS
you can:
  • open assembly
  • open part
