Change Creo View Language
Hello forum,
I have already selected "German" in the Options at "Startup":
However, Creo View still starts in English all the time.
What do I do to change the UI language to "German"?
@VeqTor, try to set the environment variable "PVIEW_LANG" to "de"and see if that makes any difference.
@VeqTor wrote:
Hello forum,
see https://www.ptc.com/en/support/article/CS96862 document.
VeqTor1-VisitorAuthor
Thanks -- I had seen these references already. However, I can't seem to locate where those Creo "environment variables" are to be found?
PVIEW_LANG is defined in Windows.
See an example on https://docs.oracle.com/en/database/oracle/r-enterprise/1.5.1/oread/creating-and-modifying-environment-variables-on-windows.html#GUID-DD6F9982-60D5-48F6-8270-A27EC53807D0 page.
