Change default name new part or assembly
- January 23, 2019
- 2 replies
- 4236 views
I think that is hard-coded into Creo with no user option to change. Even in a Windchill driven settting, we still get the prt00001 as the default name.
It would take some custom code to populate the name field with the name of the assembly it is going into and in our case that is very seldom done. We usually model the components first and then create the assembly, so the system has no idea what assembly the model is going into. How do you account for a component part that is used in many assemblies with that naming convention?
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
