Change language PTC Creo Elements/Direct Modeling Express into Spanish
  • July 15, 2015
  • 8 replies
  • 9108 views
Change language PTC Creo Elements/Direct Modeling Express into Spanish?
Thanks.
UP!
The same here. How can I change back to English?
To install Express in a given language, you need to download and install the corresponding language version, e.g. ModelingPE__setup_EN.exe
1. Navigate to Creo Elements/Direct Modeling Express 6.0 Download | PTC
2. Click Language Tab (upper right Corner) and select your language
3. Use the Search field and type in "Express"
4. Download "your" language version of Express
Please let me know if this helped.
      Max
have tried the approach described by Max Kublin to get the german version. I get the page in german, but the download link for 64 bit is again the _EN version. So i canceled the download.
woul appreciate a solution to switch to german.
Kind regards,
Matthias
It definitely worked at the time I wrote my last comment.
However, the Web Pages have been completely reworked meanwhile.
As a side effect - the German download page is currently not reachable 😞
