CHANGE THE I BEAM SIZE IN AFX BY
How can I change the I Beam size Top & Bottom Like that Top size 500 & bottom size 650 in Creo AFX Libraury.
Can you help me.
With Regards,
Rajeneesh Mishra
SamuelBrantner
Hi @RAJENEESHMISHRA
threre is an in depth video on how to customize the library here:
https://youtu.be/-iLYU-YT8e4?t=431
At minute 14:30 you can see the editing of a tab file for an I-Beam. Here is also the point where you would add your own lines with custom sizes. Just stick to the existing format and add the sizes that you want.
I hope this helps.
Greetings Sam
Greetings Sam
SamuelBrantner
Hi @RAJENEESHMISHRA
I hope this helps.
Greetings Sam
Greetings Sam
Thanx for support.
Dear sir,
I want learn the relation and parametre concept in creo.
but I have many time of study in help centre, but we are not understanding the relation and parameter in creo 7.0.3.0.
how can create the relation and parametre in basic level.
