Changing default sheetmetal bend order note label?
- April 10, 2017
- 0 replies
- 1339 views
Hello all, first post here.
Working in Creo 3.0 adding bend sequences to our sheetmetal drawings as part of a digitization/paper reduction project. I'm adding bend sequences into the part through Model->Bends-> Bend Order, then showing the desired annotations in the drawings.
The question I have is how to change the default bend order note of "BENDx" to a different tag, such as "#x"? Currently, I'm manually editing the note, but with several thousand parts to update, any step not needed to be taken will accelerate this process tremendously.
I'm also wondering if there is a way to automatically tag bends within a single sequence with a suffix in order, such a 1A, 1B etc. This is less of a concern, but I'm curious if it's possible. I've attached a screenshot of what I'm working towards.
I'm a bit green with Creo, only having been working with it sporadically for eighteen months. Having been using Solidworks since 2005, the transition has been interesting. .
