Changing placement reference for coordinate system in pro/program with IF sentence
I am using Creo Parametric Release 4.0 and DatecodeM150
I have an assembly that contains parts PRT1 and PRT2. I made a parameter KOS that allows me to choose which part is active in the assembly using IF statement in pro/program.
In the assembly i also have a coordinate system, that I would like to place on default coordinate system of whatever part is "active".I tried adding the add feature of csys inside IF statement which supresses/unsupresses either part (and changed references to the appropriate csys of part), but it returns an error that feature with that ID already exists.
Is it possible to change references for a coordinate system inside pro/program? Is it possible to use IF statement inside the add feature of csys where it requests references?
(pro/program in attachment)
