check display status to screen
  • March 16, 2017
  • 0 replies
  • 896 views
In Creo 2.0 when you performed a check display status on a drawing the results screen would automatically pop up...I am using Creo 3.0 M110 and when you perform the check display status in a drawing it pops up a menu with the options: Screen, File, Both.  Is there a setting to get this to default to "screen" each time you run check display status on a drawing?
Joe
