6-Contributor
October 14, 2026
CodebeamerX OAuth2.0 giving unauthenticated request error
I am using CodebeamerX Release 4.2 and Datecode4.2 We have configured the OpenID Configuration using Microsoft Entra authentication provider. After the configuration is done we tried to hit the below API with our instance URL to check whether the generated access token from the client id, client secret and the token uri is valid or not. API - http://10.13.27.208:8080/cb/api/v3/users/findByName?name=AutomationSyncUser Response received was Not authenticated. So is there any other options or any missing configuration to be done additionally in CodbeamerX configuration to make the Access token usable. Here are the errors that I faced Response recieved { "message": "Not authenticated", "resourceUri": "/cb/api/v3/users/findByName" }
Community Moderator
October 19, 2026
Hi ​@ptc-5278513,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
Brian Kampling
I’d suggest opening a support ticket with PTC. Given the nature of your issue it will be hard to help you troubleshoot without exposing sensitive information.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
