2-Explorer
Combined state in drawing not working.
I'd like to add color to the surface of a part in order to make clear that it needs a particular finish. I've created a combined state that shows the surface with color in the orientation I'd like.  When I add that combined state to the model, it looks perfect but only as long as the combined state is active in the model.  Once the default is selected, I still see the view but I don't see any color.  Anyone know why that's happening?  Thanks in advance.
I suggest you to ask PTC Support about requested functionality.
I had the same problem with an Assembly. I want also to use the combined state in the drawing for the Color finishing.
I made a call by the PTC Hotline.
The answer is "works to spec"
Regards Matthias
joe_morton
Any updates on this? Is this "not part of current functionality?"
We're trying to do the same thing.
hiwatt252-ExplorerAuthor
2-Explorer
Y'know, it's been ages since this issue has come up and we've found a suitable work around.  I guess I just shrugged my shoulders and let the issue die.  Would still be nice if this worked.
joe_morton
What was your workaround?
have you tried the config option?     "enable_shaded_view_in_drawings" YES
also, turn your display style to Shading with Edges
It doesn't matter if shading is done with or without edges.
