Dale_Rosema
Found it. Knew this would happen after hitting enter.
Under Tools, Click on the binoculars.
Dale_Rosema
Dale_Rosema23-Emerald IVAuthorAnswer
You can also add Component ID as a column in the model tree. It's easy to do and is very useful.
Dale_Rosema
Most of the time I do not need the ID. Only when I get the warning and need to find it in order to fix it. In this case (& I don't know why regenerating the assembly didn't work but) I needed to regenerate a subassembly pattern and the warning went away.
