Concentric/Coincident constraint for Coil Spring Axis?
I'm putting a captive screw with compression spring in one of my assemblies. The coil spring doesn't have any 'cylindrical' features or surfaces. I made a central axis, but when I try to constrain the Spring Axis to the bolt cylinder surface, it places the axis coincident/tangent to the surface, not concentric.
I always have the option to constrain Front & Right planes, but I would like to figure out how to get concentric mates with an axis.
tbraxton
One option is to add a central axis to both components and then align the axes when assembling to get what is needed.
KenFarley
I do exactly what @tbraxton  recommends - I have an axis concentric with the bolt, hole, or whatever I'm trying to line the spring up with.
I also have datum planes in the spring model that let me use its ends to position bolts, when the need arises.
Community Moderator
Hi @xPR1MUSx,
Anurag
