Apr 16, 2010 6:31 PM UTC
Concurrent Update of Model Material Condition And Drawing
Hi Experts, I recently was looking into the use of a function which will simultaneously update the physical model, as well as provide an update to the stated tolerance. The Dim bound does succesfully update the model, however the user must be careful to set the model back to its nominal condition to avoid conflicts at upper level assemblies after this process. Is there any available functionality that will perform the following updates: Assume initial condition 50 +/- 1, if you set to upper limit, it will update the model to showing 51, and subsequently update the tolerance to 51 +0/-2. This way the proE part matches the engineering drawing. Additionally, is there an alternative smart feature which allows ProE to determine whether the dimension governs the interior or exterior portion of the material envelope (I.E. automatic generation of the MMC/LMC condition of the part) to set the update rather than to the upper/lower limit of the tolerance to the LMC/MMC condition of the component? My primary interest of completing these state changes is to complete FEA analysis of fairly complex parts at the LMC condition. Regards, David Engel
Apr 16, 2010 8:34 PM UTC
Are you asking if Pro/E can create a smart feature that can determine the MMC or LMC of a dimension, depending if the FOS is an interior or exterior dimension?
Apr 16, 2010 9:25 PM UTC
I think what you are asking Is there any way to to tell pro/e to automatically generate/update to the LMC condition of a part, without going through the dimensions and doing it manually. Since the LMC will be just the opposite depending whether a dimension is an exterior or interior dimension. I don't have a clue, but pro/e seems to be capable of doing anything.
Apr 17, 2010 3:22 AM UTC
