Conditional relations
I would like to make a relation in a part to inhibate a fonction
thomething like this:
IF NBR_DOTS ==0
fontion is inibate
endif
Thanks for your help.
IF NBR_DOTS ==0
fontion is inibate
endif
I guess you want to suppress pattern of features. You cannot do this using relations. You have to use Pro/PROGRAM functionality.
See https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/#page/fundamentals%2Fprogram%2Fabout_pro_program.html%23 section in Creo Help.
https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/#page/fundamentals%2Fprogram%2Fexample_a_parametric_design_for_a_blender_cover.html%23 show how to use IF condition to suppress specific feature.
Note: You can use https://translate.google.com/ page to translate text from French to English.
sclamens1-VisitorAuthor
English is not a problem for me but it is with script. As I can see the tuto is for an assembly. I want to do this fonction on a part generated as a family. Then if I understand well what you told me it is not possible to do it.
I then going to think about a different clue.
