Config.pro setting to show all files when assembling or opening file in Creo Parametric?
Anyone know of a Creo Parametric Config.pro setting that will allow Creo to display all file types when opening or when assembling a component in an assembly?
Working in a Multi Cad environment and need to assemble other CAD system files to Creo assemblies.
Don A
KenFarley
KenFarleyAnswer
Looked through the list of config.pro options and there's no such parameter to set. But, as an alternative, you could define a mapkey to perform the steps necessary to get you to the point of selecting the file, but with "All Files" as the type specification.
KenFarley
KenFarley21-Topaz IIAnswer
