Config Stooooopidness again
  • May 15, 2014
  • 638 views
Did Creo2 M080 get infected with the same bug that early build codes had where changes to config options would not take effect nor could be saved?
Just how frustratingly stupid is our configuration file setup is now? Why do things that seems to work fine get mucked up ALL the time?????
On the off chance that it really isn't a Creo problem. (I know, what are the odds?)
1) You're sure you are editting and saving the same file in the same place?
2) You didn't save it as a config.sup?
3) Path is good?
4) You don't copy an old one over the new one on startup?
I only ask as one time(really, several times) I was changing a .c file. I'd compile and run it and no change in behaviour. Did that multiple times, including various debugging messages. Nada. Yep. I was editting one file but the one I wascompiling had the same name in a different directory. Sigh.
Answer: You've got to get that new laptop. Signs all around that this needs doing.
x
