Converting NX into Creo and extracting to .prt file
Right now we have a customer who is giving an NX file project, so we imported the model into creo and it was opened as an assembly and then I used IDD to clean it up. Now I need to extract one specific part as a (.prt file) since we will put it in CREO tool deisgn extension (which requires .prt file). I have tried (1) Copy/publish geometry however the part does not appear when I open it. I have tried (Shrinkwrap). however this option leaves holes in the surfaces. Any help will be appreciated.
Thank you.
Hi
The assistance that you need requires access to the model.
I recommend either you share the NX model here or file a case for more security and confidentiality.
Alright, noted on this. I will make a case.
Thank you.
Catalina
Community Manager
Hi @Stephen_DeLeon
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
Not sure if this work for you, but there is a hidden config.pro option called
intf3d_in_as_part YES
