Converting PDF to DXF?
  • March 28, 2014
  • 5 replies
  • 6060 views
Hey,
I've been given the task to try and find a way (free, is a must) of a way to convern pdf to a dxf. Reason being alot of suppliers are going to this method of file transfer vs sending the dxf. Any help would GREATLY be a appreicated!
Dustin
2-Explorer
March 28, 2014
Ghostview + Ghostscript + pstoedit = PDF (vectors) to DXF.
There is a better description on this site, but that's the tool chain.
If they sent bitmaps, try Inkscape; I believe it has the ability to trace bitmaps and produce vector paths.
A while ago I was looking on the same problem. I didn't find to many freware application to handle the raster to vector conversion.
Here is the list of what I tested:
pstoedit - available on sourceforge.net. Is a command line toolwhich is great for automation. The resulting dxf file consisted mainly from a huge number of disconected blocks. To us it wasn't a usable option.
WinTopo - (wintopo.com). Is a windows based, graphical interface program that has a freeware version available. I can't import PDF's (big disatvantage). It does offer a number of options and settings that allow you to get a relatively clean dxf file
Inkscape - very popular on open source world but also available as a windows application. Is quite complex, has a lot of options and settings. Since this is a editing software you also have the option to "clean-up" the file before you export to dxf. Things like removing unwanted entities, connecting lines etc. this one gived us the best results but is not a straight forward process.
I'm sure there are other applications available but those are the ones that I tested.
2-Explorer
March 28, 2014
When you mention disconnected blocks, were you reading the dxf into AutoCAD or similar?
When I used it I read the resulting DXF into a Pro/E drawing for cleanup.
PDF doesn't save primitives for geometry; everything is converted to curves - arcs, splines, whatever. The result will mostly require some attention.
The best use I made was for a computer motherboard with all its components and hundreds of pins. Converted well and was useable, but replacing the curve pieces with circles at the pins cut the clutter immensely.
If the reason for the DXF is to program CNC from, then editting is definitely going to be required.
I was trying to import in Pro/E.
By disconnected blocks I meant that all the arcs and curves were created from a lot of small entities of LINE type while I was hoping for polylines, or something similar.
I was expecting I'll have to edit the drawing but not at that level
we are using Print2CAD.
It´s not free but it is a great tool.
