Mar 19, 2015 3:02 PM UTC
Coordinate Dimensioning
I am using coordinate dimensions and I am using a reference line for my Y axis that is not the lower edge of the drawing. However, the ordinate dimensions I start with do not go negative when I insert Y dimensions that are lower than my Y zero line. How can I get them to go negative? I have tried manually adding a "-" in the ordinate dimension text but when I put the ordinate dimensions in a coordinate dimension box it erases the "-". Any advice?
Eric
Mar 21, 2015 5:25 PM UTC
Try setting the configuration option show_dim_sign value to yes.
Mar 22, 2015 8:48 PM UTC
Eric, let us know if you get show_dim_sign to work. I cannot get it to work in sheetmetal or drawings.
You might have to add it in the config.pro file before opening the session.
I cannot seem to have it show up if the session is active.
Of course, you can always add the prefix "-" to each valid dimension.
By default, it should do this in dimension tables. This is a .dtl setting.
2-Explorer
Mar 22, 2015 9:47 PM UTC
The values are the distance from the baseline. It is a shortcut for an ordinary dimension to the same location. While one might expect that a tabulation would need negative dimension values, there is no example of them in ASME Y14.5-2009.
All the examples of tabulation I've ever seen are first quadrant.
