coordinate quota
Good morning everyone
I have a problem with 2d dimensioning....
It happens to me like this: I select the "coordinate dimension" command, I choose the positioning,
I go to select the two dimensions that I am interested in inserting.....but nothing does not insert them, highlights them but nothing they remain there in their place.....
I open some old drawings and it works!!!!!!!!.....?????
Can anyone give me a tip?
Translated by the moderation using Google Translate
Buongiorno a tutti
Ho un problema sulla quotatura 2d....
Mi succede cosi': seleziono il comando " quota di coordinate",scelgo il posizionamento,
Vado a selezionare le due quote che mi interessano da inserire.....ma niente non le inserisce,le evidenzia ma niente rimangono li al loro posto.....
Apro dei drawing veccchi e li funziona!!!!!!!!.....?????
Qualcuno sa darmi una dritta?
Catalina
Community Manager
Hi @MA_1194634
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
kdirth
Here is the coordinate dimensioning help page:  To Insert a Coordinate Dimension
Is this what you are looking for?
