Copying Parameter Values from Part to Drawing (Creo 3.0)
  • April 11, 2017
  • 12 replies
  • 6533 views
How can I automatically copy parameter values from a part to a drawing on Creo 3.0?
Edit the drawing program and add lines such as:
MY_PARAMETER:D = MY_PARAMETER
or
MY_PARAMETER:D = MY_PARAMETER:MDL
(in the case of the template)
please specify, what do you mean with copy parameter values from a part to a drawing ...
For example: You can put model parameter in drawing table using notation ... &model_param
MH
gquiroga1-VisitorAuthor
Both the part and the drawing have the same parameters, and I want to inherit the parameter selected values from the part to the drawing.
unfortunately I still do not understand why you want to have drawing parameters. How do you use drawing parameters ?
MH
Here is another example this mapkey =asmnum takes one single part parameter and transfers it to the drawing.   The parameter name that it copy's is PCB_ASM_NUM
=asmnum @MAPKEY_NAMECopy PCB Assembly parameter to drawing;@MAPKEY_LABELPCB ASM NUM to Drw;%=asmnum_del;%=up;%=asmnum_drw;
Again this mapkey calls upon two other mapkeys shown below.
=asmnum_del @MAPKEY_NAMEDelete PCB_ASM_NUM;@MAPKEY_LABELDelete PCB_ASM_NUM;~ Activate `main_dlg_cur` `page_Tools_control_btn` 1;~ Command `ProCmdDwgParameters` ;~ Arm `relation_dlg` `ParamsPHLay.ParTable` 2 `rowPCB_ASM_NUM` `name`;~ Disarm `relation_dlg` `Pa
=asmnum_drw @MAPKEY_NAMEInsert PCB_ASM_NUM;@MAPKEY_LABELInsert PCB_ASM_NUM;~ Activate `main_dlg_cur` `page_Tools_control_btn` 1;~ Command `ProCmdDwgProgram` ;#EDIT PROGRAM;#INSERT LINE;PCB_ASM_NUM:D=PCB_ASM_NUM;;#DONE/RETURN;
