Cosmetic sketch properies are inaccessable.
I cannot access the "Properties" of the cosmetic sketch. I've tried the RMB and the instructions in CS97994. When following the instructions of CS97994 the Properties menu selection is grayed out. BTW: Using Creo 2 M100
N.BarnesAnswer
You have to "Edit the Definition", Select "Section Setup", then there is a tab for "Properties" in that menu.   Yep, that was intuitive.
Barnes,
I can access Properties tab in Sketched Setup dialog box in CR2 M070 and M150. Can you upload your model ?
Martin Hanak
I don't think you can set the properties of the "Cosmetic Sketch" in the same way as regular sketch.
That's because each entity in a cosmetic sketch can have its own linestyle / color...
So if you want to change them, edit the sketch, select all the entities, then right-click and select "properties"...
N.Barnes15-MoonstoneAuthorAnswer
