Create a analysis feature that will give you the bounding box size
Would like bounding box size option within the analysis feature.
Must have ability to create parameters for each of the 3 distances example: (height, width & length).
Would be nice if it could tell the difference between if the geometry was rectangular or round. If round provide parameters diameter & length.
The evaluation needs to be able to evaluate simplified rep of part and/or assembly.
Use case:
The parameters within the analysis could be used to establish bill of material parameters (part size for raw material purchases).
Assembly level can be used to establish packaging size requirements.
Also we need this feature here. This should be fairly simple to implement an analysis feature that allows to know the bounding box for solid geometry, excluding any other type of feature like datum and surfaces.
6-Contributor
Creo View provide this functionality but Creo Parametric doesn't. This is really a pity.
I want it!
if this thing available then it is mostly helpful in BOM
I want it!!!
