Create a image that you can rotate with help of a CAD assembly
Hello how do i create an image that you can rotate and look at The product from different sides? Often used at webpages. Here is an exanple:
http://lh-camera.dk/en/products/underwater-video-camera/hd-underwater-video-camera/
You can here rotate the image of the camera?
Can you do this with an cad file?
StephenW
StephenWAnswer
I saved the attached simple part as a u3d pdf file and it initially opens in acrobat reader 11 looking like a screenshot but there is a 'CLICK TO ACTIVATE' notification that is on the window and then a "3D CONTENT HAS BEEN DISABLED" notification also. Once I click to activate and enable the 3D content option, I can rotate the file.
kdirth
Saving it as a 3D PDF is the only method within CREO I know of.
I did not find any 3d pdf ? what is the name of the file format?
StephenW
Under FILE - SAVE AS - SAVE A COPY.
set type to PDF or PDF U3D
StephenW
VRML used to be the way to do it. I don't know if that is still an option though.
hmm okey, have not heard about that
StephenW
If I remember correctly, you can open the VRML file (.wrl) in internet explorer.  It has been 15 or more years since I used that format so I don't remember any of the details.
You'll probably benefit from googling it.
