Apr 5, 2018 1:54 PM UTC
Create a Layer for hiding thread notes in 3D model
I would like to create a layer in order to hide the thread notes which are normally visible when I enable "show annotation display".
I need to do it at master assembly level, including the thread notes of all the holes/cosmetic threads in all the submodels (parts and subassemblies).
The problem is that once I tick the option "include submodels" in the rule editor window, and confirmed with ok, it doesn't keep the option if I come back editing the rule (video here below):
(view in My Videos)
(with the result that the notes of sublevels are not included in the query results).
Or, as an alternative, is there another better way to hide thread notes by default?
thanks
Apr 10, 2018 2:56 PM UTC
In your first video it looks like you are adding rules to an existing layer. Since that's an assembly layer and you are finding items that are not assembly items (notes in other parts and assys), it fails.
In the second you are creating a new layer from the find tool.  Note the "propagate layer" box is checked (around 27 seconds).  I'm not certain, but I'd guess that means it's creating that layer in every model, or at least in every model that had notes.  At the end, notice that the symbol next to NOTES in the layer tree is indicating a bundle of layers, not a single layer.
Regarding finding only hole notes, try this:
You want to look for notes by a certain type of feature, in this case hole features. I believe that will capture only the hole notes and not others.
Apr 10, 2018 11:50 AM UTC
I'm guessing that it's failing because of a limitation on placing submodel items on an assy level layer.  The good news is that once you have the layer in your assy, you can easy pass it down to the other models in the tree.
Here are some mapkeys that we use that might help you get there.  These are Creo 2, but I believe will work in Creo 3.  I've not tested them in Creo 4 or 5.
First one resets the find tool so that it's in a predictable configuration for running later makeys:
mapkey la-rf @MAPKEY_NAMEReset Find;@MAPKEY_LABELReset Find;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdMdlTreeSearch.edit_t`;\
mapkey(continued) ~ Update `selspecdlg0` `SelOptionRadio` `Feature`;\
mapkey(continued) ~ Activate `selspecdlg0` `SelOptionRadio`;\
mapkey(continued) ~ Update `selspecdlg0` `LookByOptionMenu` `Feature`;\
mapkey(continued) ~ Activate `selspecdlg0` `LookByOptionMenu`;\
mapkey(continued) ~ Select `selspecdlg0` `RuleTab` 1 `Attributes`;\
mapkey(continued) ~ Select `selspecdlg0` `RuleTypes` 1 `Name`~ Select `selspecdlg0` \
mapkey(continued) `CascadeButton1`;~ Close `selspecdlg0` `CascadeButton1`;\
mapkey(continued) ~ Activate `selspecdlg0` `CondBuilderCheck`1;
The second one adds a note layer to the top level assy (it calls the reset find mapkey automatically):
mapkey la-no @MAPKEY_LABELAdd 00_NOTE;%la-rf;\
mapkey(continued) ~ Open `selspecdlg0` `SelOptionRadio`;~ Close `selspecdlg0` `SelOptionRadio`;\
mapkey(continued) ~ Select `selspecdlg0` `SelOptionRadio`1 `Note`;\
mapkey(continued) ~ Close `selspecdlg0` `CascadeButton1`;\
mapkey(continued) ~ Activate `selspecdlg0` `SaveResults`;\
mapkey(continued) ~ Update `save_rules_dlg` `LayNamePanel` `00_NOTE`;\
mapkey(continued) ~ Activate `save_rules_dlg` `LayerPropagateCheck`0 ;\
mapkey(continued) ~ Activate `save_rules_dlg` `OKBtn`;~ Activate `selspecdlg0` `CancelButton`;
This one selects all of our company layers, which begin with 00_.  You could modify it to replace the 00_* with your notes layer name:
mapkey la-sd @MAPKEY_LABELSelect all CE layers;\
mapkey(continued) ~ Command `ProCmdViewLyrs` 1 ;~ Command `ProCmdLayer_TreeSearch` ;\
mapkey(continued) ~ Close `main_dlg_cur` `PHTLeft.PHLayerUI.LayerShowBtn`;\
mapkey(continued) ~ Open `layertreequery` `CmpMethodRadio`;\
mapkey(continued) ~ Close `layertreequery` `CmpMethodRadio`;\
mapkey(continued) ~ Select `layertreequery` `CmpMethodRadio`1 `=`;\
mapkey(continued) ~ Input `layertreequery` `ValueInput` `00_*`;\
mapkey(continued) ~ Update `layertreequery` `ValueInput` `00_*`;\
mapkey(continued) ~ Activate `layertreequery` `AddBtn`;\
mapkey(continued) ~ Activate `layertreequery` `SelectAllBtn`;\
mapkey(continued) ~ Activate `layertreequery` `CloseBtn`;
Lastly, this one extends the rules of the selected layers to all components in the assy, effectively duplicating the layer in every model all the way down the tree.  (It calls the selection mapkey automatically.)
mapkey la-er @MAPKEY_LABELExtend CE layer rules;%la-sd;\
mapkey(continued) ~ Close `main_dlg_cur` `PHTLeft.PHLayerUI.LayerEditCasc`;\
mapkey(continued) ~ Activate `main_dlg_cur` `PropagateBtn`;
You can then combine this into one mapkey that calls la-no and la-er to do this with one mapkey.
I hope that helps.
tleati12-AmethystAuthor
Apr 10, 2018 1:41 PM UTC
Hi Doug,
thanks for your detailed reply.
Don't know why it fails to propagate down to the sublevels in the layer definition window (as show in my first message), but it's weird that there is instead no problem in propagation by creating the layer with this procedure:
which is working indeed for my purpose.
But, the big problem of this way, is that this layer is hiding ALL the notes in my model(s), not just thread notes ( so hiding also text notes which I often insert for any reason).
There should be for sure a way to hide just thread notes.
My goal is to hide them by default in the start part, so that they never show up by themselves in the 3d window.
Bye
