3-Newcomer
Create a Part file using Assembly positions control using Multibody option.
Can we create a Part file(.Prt) using 2 Different parts from backup with Assembly positions control using Multibody option.
example: I have two different parts Models created in creo as two seperate parts, But I need to create as a single Part file. Can we create using Multi body option? If so, how we can be able to bring geometry to a part file with parametric.
tbraxton
Yes, this is possible. You will need to create a new part in Creo 7+ (multibody support). This will not be automatic, if you want the feature tree to be duplicated then you will have to rebuild the geometry in the new part. It may be easy to use copy/paste special to copy the features into the new model or it may be really tedious and not worth it.
If you just need the part with two bodies in it, then export each of the parts as Creo neutral format and import the neutral files into the new part while creating a body for each import positioned relative to each other as required. This should be very fast to implement.
