Create a surface using multiple curves
I have an electronic board on which I'm trying to create a surface across all the pads. I can with the projection tool into the sketch but this is very tedious.
I did it on 3 pads to give you an idea, but the surface should be present on all the grey pads. This surface will be use in creo machining for programming a laser machine in order to clean the pads.
I try to create a section then a curve from it but I can't fill in the curve...
Do you have any ideas ?
Thanks in advance
assumption: all pads have some height dimension ... let's say 1 mm
Steps to follow:
1.] in assembly create planar x-section X1 parallel with top face of green desk with distance 0.5 mm
2.] create Curve from Cross Section and select X1 ... you will get single curve containing outlines of all pads
3.] create Fill surface in some plane parallel with top face of green desk
4.] select single line from curve defined in 2.
5.] edit chain properties of selection
6.] select all curves using following setting
7.] finish the feature
Steps to follow:
RJ_FR12-AmethystAuthor
Great, it works ! Thanks a lot !
