Create STL from assembly (3 parts)
Hi all,
I am trying to create an stl file from an assembly (for export and import to a electrothermal simulation software).
When I export the assembly as .stl, only one part is created / "meshed" (see attached picture), also when adjusting the parameters.
Anybody with any advice what to do to export the complete assembly as STL?
Thanks in advance!
Best
Annemarie
2017-05-24 14_15_15-IGS-WE-HCI-1890_WE-PERM2-REV1 (Aktiv) - Creo Parametric Student Edition (for edu.png
thanks for the reply.
I have either .stp or .igs and open them as assmblies. None of the file formats work to create the .stl
What can I do?
Mahesh_Sharma
22-Sapphire I
May 24, 2017
Annemarie,
Check the part ,which was not included in STL, is not a surface model.
ahofmann-21-VisitorAuthorAnswer
What can I do?
Any ideas / help ?
Thank you!
StephenW
You would be helping the entire community if you described your solution and set it as the answer to your question.
I created the assembly myself from the single parts and did not open -stl or .step files from the supplier.
