Creating a double side fillet weld with different thickness
Hello World,
I have an assembly model in Creo, and I am trying to use the Weld application to add some welds to the assembly. I am trying to use the "Fillet Weld" option to create a double sided filled weld. One the arrow side, I need the fillet weld to be 0.5 inch. On the other side, I need the weld to be 0.25 in thick. In the filltet weld dashboard, there is an option to create double side fillet weld. However, it only allow me to define a single weld thickness for both sides. Is there a way to define different weld thickness for a double side weld in the weld dashboard?
Thanks in advance.
