Creating BOM table in Creo Drawing involving sub assemblies components
I have an assembly model that involves 2 sub-assemblies. When I add automatic BOM table the subassemblies appears in the table, while I need to add a BOM table to the assembly drawing covering all components ( main and sub-assembly).  Can anyone have a solution (BOM of all components and not subassembly names)?
you can apply filter on your repeat region. Something like
&asm.mbr.type == PART
StephenW
Your BOM table is set to be "FLAT". You can change to be "RECURSIVE"
Go to the table tab, repeat region, select attributes, select your table, select recursive then done.
Thanks Stephen
I followed that process and now I have all the parts and also assemblies name on the table, how I can remove the assembly items from the BOM table?
Hi Martin
it works!
Thank you all
