3-Newcomer
Aug 13, 2026 2:49 AM UTC
creo打开文件闪退, 卡顿
I am using Creo Parametric Release 7.0 and Datecode7.0.3.0 creo7.0打开模型出现闪退,使用Creo view也出现闪退, 需要验证是否文件被损坏, 此外CREO运行卡顿。 联系电话 13696984584 陈工 邮箱 czy@xmhfty.com
KenFarley
Aug 13, 2026 11:32 AM UTC
For this type of problem you’re going to have to contact PTC, not post about it on a user forum. They’re going to probably need to have access to the file in question. They may be able to recover your file from the corrupted one.
If you have any old versions of the file you could try opening one of them and see if there’s a point in time where the model doesn’t crash Creo. Every time you save a file Creo keeps a copy on disk of the file in the state it was previously saved. So you have parts like “part.prt.1”, “part.prt.2”, “part.prt.3”, etc. I would try opening the file with the second highest number, see if that crashes. If it does, open the next lower version, test, etc. Could be a lengthy process, but might at least get you something useable.
Here’s the help file stuff about opening old versions of files:
https://support.ptc.com/help/creo/creo_pma/r12/usascii/index.html#page/fundamentals/fundamentals/Retrieving_an_Earlier_Version_of_a_File.html
