3-Newcomer
Creo 10 Visualizer freezing after disconnecting from dock
Recently was assigned a new laptop at work with a 4K, 120Hz screen. I have now found that whenever I unplug my laptop from the docking station (2 1080p 60Hz monitors), the visualizer in Creo freezes up and is unresponsive. I am still able to use the model tree/configuration ribbon, and opening new windows results works just fine.
When reconnecting to the dock, all the windows start working again without issue. I have to assume this is something with my display settings. I have attempted to fix this issue by disabling Integrated Graphics and adjusting screen resolution and refresh rate, with no success.
Community Moderator
Hi @CJ_12230165,
Thank you for your question.
Anurag
