Creo 11. How to change color of a dimension in 2d drawing, on the fly.. after creating the dimension?
- 3 replies
- 159 views
- Translate All
Hi, In Creo 3 I was able to add a dimension to a 2d drawing and while the dimension was still highlighted red...I could change the font, color and size.
We then jumped to Creo 7, and it seems this no longer works.
We are now on Creo 11, and it still doesn't work. I can change the font, and the size..but color does not stick if I just created the dimension. If the dimension is already existing, and i click on it….. i can change the color.
I want to change the color on the fly. I am trying to create a mapkey to do this, but i cannot get this color to change if I try to run the mapkey on the fly, after creating the dimension. (with the dimension still highlighted)
If I run it on an already existing dimension, it works fine.
What am i doing wrong?
see recording
