6-Contributor
Creo 12 Cabling Terminals setup from Creo 8
My Company recently ungraded to Cero 12 from 8. There are a few changes made to the whole cabling side of Cero. I have been able to work through most of it but now trying to add the terminal information has been tricky/I can’t get it to work.
In the past we have added in the terminal table to get all that information and eventually use it when making the drawing in the to-from table. We also have another smaller table with some of the same info for each connector.
To make the BOM accurate we make blank parts with the part numbers of terminals, locks, and seals and place them in the assembly so the table is accurate.
So far I’ve tried making new terminals which just throws the “name already exists” error and when I try and import them from the old trm files the same thing happens. I would assume this is because there are part files that already exist and not from the trm files.
If anyone has a solution or work around that would be much appreciated.
Catalina
Community Manager
Hi ​@AL_13006242
Thank you for your question. 
Catalina | PTC Community Manager
