3-Newcomer
Nov 19, 2026 6:55 PM UTC
Creo 12 Datum creation on existing drawing overlap tolerances but fine if create new from scratch
Copy drawing and model and want to fix datum callouts (we use display per ASME Y14.5m-1982) but they overlap the tolerances but if I create a new drawing they display correctly. I have tried copying drawing option .dtl file, place them in the model and then show on the drawing and tried to do it just to do it on the drawing level. I’ve also tried creating new views on the same drawing and create them or show and doesn’t work. I don’t want to fake them with the @[-A-@] either. I’ve searched the internet but have not found anything to correct this issue.
COPIED Drawing & Model
NEW Created using same model
