Mar 6, 2014 9:04 PM UTC
Creo 2.0 Parametric and PDMLink
I have just run across a problem that I cannot seem to solve. When I search on a part in PDMLink and go to the Actions, I normally pick on Open in Pro/Engineer. This adds the file to my workspace, downloads and opens the file all in one pick.
I just tried this and I get a failure stating that the .pha file cannot be opened. This is from the embedded browser. I have checked my file associations and all seems to be fine there. If I download the file to workspace and then use the Open in Pro/Engineer all works as you would expect.
Has anyone else seen this? If so, how do you fix it?
Currently running Creo Parametric 2.0 M090 and Windchil PDMLink 9.1 M070.
Ron Grabau
11-Garnet
Jun 21, 2017 4:23 PM UTC
Yes I am starting to see this as well. I am using PDM LInk 10.2 CPS22 and Creo 2 build m120
