CREO 2 Hole Table Note Help - Only Show PATTERN_NO if more than 1
I am trying to set up a company hole table that everyone can use to better format hole notes on our drawings. I have it set up and working well but the one major annoyance is the &PATTERN_NO parameter. I want it included for when there is a pattern but when there is just one hole it displays "1X"
Is there a way to add a condition that will not display that is the &PATTERN_NO is 1.
Sample CALLOUT FORMAT: &PATTERN_NO X <CTRL-a>n<CTRL-b> &DIAMETER[.1] <CTRL-a>x<CTRL-b> &DRILL_DEPTH[.1] / &METRIC_SIZE &VAR_THREAD &THREAD_DEPTH[.1]
Josh
They did seem to fix that in Creo 3
jzarecky1-VisitorAuthor
Thanks. Good to know but unfortunately for now our Windchill is not supported by Creo 3 so we are stuck on 2.
Josh
I am using Creo 11, I have same question on this. Is any way available now to do it?
