Creo 3.0 crashes when exporting to PDF
Creo crashes with no error message when trying to save certain drawings to a PDF, both quick export and save as. I have no idea what differentiates the ones that are saved from the ones that cause the crash.
Mahesh_Sharma
22-Sapphire I
Ok, found the article for this exit , Article CS261585.
If you are not in maintenance, content of that article is as:
Description
  • Premature exit occurs when exporting a specific drawing as PDF
  • Exit when printing a pdf
Cause
Resolution
Mahesh_Sharma
22-Sapphire I
You may try contacting Technical Support.
Datecode of Creo 3.0?
Any traceback?
alekseyj1-VisitorAuthor
You'll have to forgive me, I am still pretty new to Creo. Where do I find the datecode and traceback information?
Mahesh_Sharma
22-Sapphire I
File > Help > About Creo, you will get datecode.
When Creo will exit, there will be a message for Auto-traceback, check that message for location of traceback.
You can open a new support Case here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
Mahesh_Sharma
22-Sapphire I
Description
Cause
Resolution
Blows my mind how something like this went on for 6 iterations of the program
