Jan 18, 2017 1:09 AM UTC
Creo 3 M110 unable to open Creo 4 part file.
Weird!
I recently sent a part file created in Creo 4 to a customer who uses Creo 3 (M110) and he was unable to open the file.
The error "unable to open file"
Anyone come across this?
Jan 18, 2017 1:32 AM UTC
Have not heard that Creo4 is special in this regard,  but I could be wrong...
Historically,  Pro/E-Creo has only been forward compatible,  not backward compatible. (Creo4 CAN open Creo3 files,  but Creo3 CAN NOT open Creo4 files)
Seems like a normal error to me.
Good Luck
Bernie
Owner / Designer / Builder
www.grumancreations.com
Jan 18, 2017 1:28 PM UTC
See this post: GRANITE-based Cross-Release Interoperability for Pro/ENGINEER - PTC.com
There's a way to make Creo files appear as read only when being opened in older versions but it doesn't look like it supports Creo 4 yet (Creo 4 is at it's first build code (F000) which should not be used in a production environment yet). It may just be easier to share STEP or IGES files if you want to keep using Creo 4.
