Jan 13, 2018 5:36 PM UTC
Creo 4.0 vs. Creo 3.0 Configuration Options
- 2 replies
- 4400 views
- Translate All
The attached Excel spreadsheet contains a comparison of the Creo 4.0 configuration options vs. the Creo 3.0 configuration options. The first tab shows the new 4.0 options that are available as of M030, and the second tab shows the 3.0 options that are in M150 but do not appear to be in 4.0.
I haven't verified if all the 3.0 options are truly gone; I was surprised that step_export_format, for example, was not listed in the 4.0 CSV file from PTC. Also, I performed the comparison manually using Excel, so forgive any mistakes. But I believe it is reasonably accurate.
dmartin@creowindchill.com
