8-Gravel
CREO 4 MASS CALCULATION OF ZERO
I have a stencil that I'm adding to an assembly just to show it graphically and I want the weight of the part to be zero.  Is there a way to assign a weight to a part that has the mass parameter locked?
StephenW
StephenWAnswer
My suggestion is to change the density of the stencil to be a very small number so the mass of the part would effectively be zero. You would do that under File - Prepare - model properties - mass properties change. Modify the density as required.
You can "assign" mass but getting the upper level assemblies to use the assigned mass is a setting that will allude future users attention. To be honest I can't really remember how to make the assigned mass show up consistently, it's always something I have to research.
StephenW
StephenW23-Emerald IIIAnswer
MarcHaren8-GravelAuthor
8-Gravel
That's what I was doing but I was hoping I could just give it a value of zero.  We also have some other parts that have that have an assembly weight but were created as parts that I was hoping to just assign a weight rather than finding out the volume and doing the calcs.  I guess I'll just have to run with that answer thanks.
StephenW
Don't give up completely, it is absolutely possible to assign mass and have your assemblies use that. I just don't remember exactly what all it takes to make it happen correctly and what sort of training you would have to give to your fellow users so they would understand and recognize when to use it and set it in their assemblies.
to get model with zero mass make it as surface model (not solid).
File
Prepare
Model Properties
Mass Properties --> Change
Define Properties by   --> Fully Assigned
Enter Mass = 0 kg
