Jun 27, 2022 1:21 PM UTC
creo 6 crashes with cinfig option pro_format_directory set
I am using Creo Parametric Release 6.0 and Datecode6.0.3.0
Creo 6 crashes due to config options after upgrading from creo 3
StephenW
Jun 27, 2022 1:49 PM UTC
So if you removed the option pro_format_directory from the config, Creo doens't crash?
Jun 27, 2022 1:51 PM UTC
yes..
StephenW
Jun 27, 2022 1:56 PM UTC
Does your format directory have spaces? I think they fixed that but it may still cause problems.
TomU
Jun 27, 2022 3:18 PM UTC
There were a couple builds of Creo 6.0 and 7.0 that had serious stability issues.  I can't remember if 6.0.3.0 was one of those or not.  Have you tried using the latest build (6.0.6.0) to see if the issue is still reproducible there?  Something else to try is removing ALL of your config options except just this one.  It's possible that while this config option is causing crashing, it only happens in conjunction with some other config option.
